Default Color Scale Options
Posted: Mon Mar 27, 2017 3:19 pm
by I/O Design
I like the recent improvements to the color scale (custom labels) but think there are a few more things that could make it more user friendly.
1. ability to set a default color scale
2. ability to set a default number of steps for custom color scales within the color scale editor
3. sort the color scale drop-down menu alphabetically
Re: Default Color Scale Options
Posted: Mon Mar 27, 2017 7:11 pm
1. Do you mean to set a default color scale for CloudCompare? Instead of using the default 'rainbow' one?
2 & 3. Good ideas!
Posted: Mon Mar 27, 2017 7:42 pm
by I/O Design
I was thinking it would be nice to be able to choose any one of the existing or custom scales and set it as the default for any imported point clouds. I often conduct several comparisons and need to change all the color scales. It could potentially be a drop down in the Display options under Color scale (scalar field). It may be nice if you could set separate defaults for imported clouds, clouds used in cloud-to-cloud comparisons, and clouds used in cloud-to-mesh comparisons.
Posted: Wed Mar 29, 2017 6:52 am
A global setting (in the 'Display options' dialog) could be added indeed. But several options would be very heavy (also in terms of development ;).
I already modified the code to sort the color scales. I'll see what I can do for the default number of steps.
Posted: Wed Dec 15, 2021 9:47 am
by daanbl
Apologies for reviving an old thread, but is there any news on this functionality? I'm having the same issue where I regularly load a large number of point clouds and then for each one separately have to set the right color scale and number of steps. It would be great if a default option could be made, or if it were possible to select multiple clouds and change the color scale for all in one go.
Posted: Thu Dec 16, 2021 8:30 pm
Nope, this has not been implemented and it's still in the long TODO list...
