complie the cloudcompare in the windows 7
snfge
Re: complie the cloudcompare in the windows 7
Post by snfge »
HI , I set the "OPTION_USE_EXF_LIB" is "D:/CloudCompare/trunk-20150519/dxflib-3.3.4-src/src", does here hase some problem?
Well if the project compiles properly afterwards, then it should be ok...
snfge
Post by snfge »
Hi , In the "dxflib", it only hase *.cpp and *.h, it oK, it need hase the lib file?
Nope, CMake will create a dedicated 'project' for this library. You should see it in Visual Studio (if you compile with VIsual?).
snfge
Post by snfge »
Hi
When I complie the cloudcompare in vs2010, it can create the "DXF_LIBd.lib", but I can not read the dxf file. why? could you give me your email address, I can send some picture to you. thank you.
Yes: cloudcompare [at] danielgm.net (replace the [at] by @)
