[Fixed] Crash when Link Camera is enabled
Steve L~
Post by Steve L~ »
Hi All,
I have a repeating crash as soon as I check the 'Camera Link' option.....
Windows 7, 64bit, NVIDIA Quadro graphics card.
Great work BTW...!
Steve
Re: Crash when Link Camera is enabled
Hi, thanks for the feedback!
I can't reproduce the bug right now (while I have the exact same configuration as yours). However I'll try to investigate this (and test it on other computers).
Have you successfully used this tool before (with a former version) or is it your first attempt?
Steve L~
Post by Steve L~ »
I've just installed CC over the last few days so I'm still experimenting a bit (& liking it a lot so far!)
Is there any crash dump log or anything else I can post up that might help you investigate?
Steve
No sadly...
But here is a last question: does CC crash when you check the 'Camera link' check-box or does it crash only once you rotate one of the 3D views?
Ah! I finally found the bug! This is fixed in the current trunk version (will be available in the next release).
Steve L~
Re: [Fixed] Crash when Link Camera is enabled
Post by Steve L~ »
Daniel,
Sorry just spotted your question but I guess you've figured it out now, it crashed as soon as the tick box was enabled....
Steve
No problem. I finally found a computed on which the crash occurred and I managed to find the cause. It's fixed in the next version (should be out tomorrow!).
