Unroll
Cylindrical shape to unroll
Cylindrical shape unrolled
Unrolled cone
Cylinder
'Unroll cylinder' dialog
  • cylinder radius
Cone
'Unroll cone' dialog
Straightened cone
Export deviation scalar field
