Colors\From Scalar fields
This tool is accessible via the 'Edit > Colors > From scalar fields' menu entry.
Sets the color components (RGBA or HSVA) from one or several scalar fields.
Dialog
The tool allows to set separately for each color components:
  • the source scalar field
  • 'Minimum' and 'Maximum' fields: the minimum and maximum values (range) inside which the scalar field values will be mapped
  • 'Fix' checkbox: whether to use a fixed value instead of a scalar field
  • 'Reverse' checkbox: to map the scalar fields values in the reverse order
It is also possible to map the values to the RBB or HSV color spaces ('Mapping type' radio buttons at the top).
Edit > Colors > From scalar fields dialog
