New pages
- 08:33, 2 December 2023 Colors\From Scalar fields (hist | edit) [775 bytes] Daniel (talk | contribs) (Created page with "== Menu / Icon == This tool is accessible via the 'Edit > Colors > From scalar fields' menu entry. == Description == Sets the color components (RGBA or HSVA) from one or se...")
- 07:49, 2 December 2023 Plane\Flip (hist | edit) [185 bytes] Daniel (talk | contribs) (Created page with "== Menu == This tool is accessible via the 'Edit > Plane > Flip' menu entry. == Description == This function simply flips the selected plane(s). The plane(s) normal will be...")
- 07:18, 2 December 2023 Cloud-to-Primitive Distance (hist | edit) [986 bytes] Daniel (talk | contribs) (Created page with "== Menu == This tool is accessible via the 'Tools > Distances > Cloud/Primitive dist.' menu entry. == Description == Computes the mathematically correct distance between a...")
- 05:36, 2 December 2023 Plane\Compare (hist | edit) [523 bytes] Daniel (talk | contribs) (Created page with "== Menu == This tool is accessible via the 'Edit > Plane > Flip' menu entry. == Description == This function simply flips the selected plane(s). The plane(s) normal will be...")
- 05:35, 2 December 2023 Polyline\Sample points (hist | edit) [247 bytes] Daniel (talk | contribs) (Created page with "== Menu == This tool is accessible via the 'Edit > Polyline > Sample points' menu entry. == Description == Samples points along a polyline. The user can choose a fixed num...")
- 05:32, 2 December 2023 Mesh\Mesh scan grids (hist | edit) [628 bytes] Daniel (talk | contribs) (Created page with "== Menu == This tool is accessible via the 'Edit > Mesh > Mesh scan grids' menu entry. == Description == If a cloud has 'scan grids' associated (for 'structured' clouds loa...")
- 05:24, 2 December 2023 Mesh\Flip triangles (hist | edit) [520 bytes] Daniel (talk | contribs) (Created page with "== Menu == This tool is accessible via the 'Edit > Mesh > Flip triangle' menu entry. == Description == This tool changes the order of the vertices of every triangle in the...")
- 05:20, 2 December 2023 Normals\Set SF(s) as normal (hist | edit) [553 bytes] Daniel (talk | contribs) (Created page with "== Menu == This tool is accessible via the 'Edit > Normals > Set SF(s) as normal' or the 'Edit > Scalar fields > Set SF(s) as normal' menu entries. == Description == Uses u...")
