Sensors\Ground Based Lidar\Create
Edit > Sensor > Create > GBL sensor dialog
Note: since version 2.5.6, angles are now expressed in degrees and aircraft denominations (yaw/pitch) are used so as to make things clearer.
Clicking on the 'OK' button will create a new sensor object. A depth map is automatically generated and displayed by CloudCompare so as to let the user visually check the parameters.
GBL sensor depth map
GBL sensor object (as visible in the DB tree and in a 3D view
