Rasterize
Generating a raster grid
- since version 2.13:
- similarly, if the 'project SF(s)' option is checked, scalar field values can be 'projected' onto the raster as well. When multiple points/SF values fall inside the same raster cell, CC can extract the single SF value for this cell as:
- the minimum SF value
- the average SF value
- the maximum SF value
- the median SF value
- or the inverse variance
Empty cells
- interpolate (see below)
Interpolating empty cells
Interpolate
Kriging
Grid position
Interpolate scalar fields
- median value
- inverse variance
Resample input cloud
Export
Cloud
- Since version 2.13:
- 'median': median value
Raster
ASCII matrix
Contour plot generation
The user must specify:
Since version 2.6.2
Hillshade
- click on generate
