M3C2 (plugin)
Jump to: navigation, search
Computing M3C2 distances
Main parameters
  • either the whole cloud
Advanced
The 'Advanced' tab contains... advanced parameters. Their name should talk for themselves. They can be ignored by most users.
Output
Save/load parameters
Computing distance
