Display modes
Jump to: navigation, search
Main display modes
CcOrthoMode32.png Orthographic view
Perspective view
CcCenteredPerspective32.png Object-centered
CcViewerBasedPerspective32.png Viewer-based
Fullscreen
CloudCompare has two different "fullscreen" mode:
  • either a standard fullscreen application mode (shortcut: F9)
  • or an 3D view exclusive fullscreen" mode (shortut: F11)
In exclusive fullscreen mode, only the active 3D view is made fullscreen (and will stay on top). This mode can be left by pressing on F11 again, or using the 'Leave fullscreen mode' icon that appears when the mouse hovers the upper-left part of the screen.
These options are also available via the 'Display' menu.
Bubble-view (polar)
To enable this mode:
  • highlight the sensor entity in the DB tree and click on the 'Apply' button in its properties (Viewport section)
  • or press the B shortcut if a sensor or an entity associated to a sensor object is highlighted
To leave this mode the user must click on the CcExit.png icon in the top left corner of the 3D view.
Stereo mode
To activate one of the stereo modes, the user must click on the CcStereo.png icon in the left '3D view' toolbar. The following dialog will appear:
Anaglyph
Please note that:
NVidia 3D Vision
  • by pressing the F11 key
  • by clicking on the 'Leave fullscreen mode' icon that appears when the mouse hovers the upper-left part of the screen
Oculus Rift
