Cross Section
This tool is accessible via the CcClippingBox small.png icon the upper main toolbar or the 'Tools > Segmentation > Cross Section' menu.
Additionally, this tool can:
Editing the clipping box
Interactively
Numerically
Visualization
Extract a single slice
To do this, simply click on the 'Export slice' CcClippingBoxSingleExport small.png button (in the right-side 'Slices' frame). CloudCompare will then create new entities and add them to the database tree.
Extract a single envelope
To do this click on the 'Extract envelope' SmallPolygonSelect.png button (in the left-side 'Envelope/Contour' frame).
Additional options are:
Extracted envelope (close-up with the slice cloud)
Extract contours inside a single slice
Extracted contours
  • you can easily 'cancel' (delete) the last generated envelope or contours by clicking on the 'revert' icon next to the SmallPolygonSelect.png button
Extract multiple slices, envelopes or contours
To extract several slices, envelopes or contours at once, click on the 'Extract multiple slices' CcClippingBoxMultExport small.png icon (in the right 'Slices' frame).
Other parameters are:
Multiple slices (left) and envelopes (right) extraction
Reset the clipping box
You can reset the clipping box to its original state (i.e. the cloud bounding-box) anytime by clicking on the 'reset' SmallReset.png button in the upper right part of the dialog.
Close the tool
You can close the tool by clicking on the 'red cross' SmallCancel.png button in the upper right part of the dialog.
