Cork (plugin)
Since version 2.12, consider using the Mesh Boolean plugin, which is slower but supposedly more robust.
  • select two meshes (meshes should be ideally closed, otherwise the output might be wrong)
  • click on the plugin icon (or the equivalent entry in the 'Plugins' menu: 'Plugins > Mesh Boolean Operations')
  • when the plugin dialog appears (see above):
    • assign each mesh to a role (A or B)
    • then select the operation to apply:
      • union: A + B
      • difference (symmetric or not): A - B
      • intersection: A n B
Warning: due to internal instabilities in the current version of the Cork library, it may be necessary to launch the process several times in order to get it working ;)
