Compilation
Jump to: navigation, search
Prerequisites
Generating the project
    2. qCork (see below)
    4. qEDL
    5. qHPR
    6. qKinect (see below)
    8. qPCV
    9. qPoissonRecon (see below)
    11. qSRA
    12. qSSAO
    1. On Visual C++ (Windows):
[Optional] Setup for the qPoissonRecon plugin
The version of the Poisson Surface Reconstruction library (M. Kazhdan et al.) used by the is [1]. It is declared as a submodule of CC's repository. You have to explicitly synchronize it (see [2]).
Then simply check the INSTALL_QPOISSON_RECON_PLUGIN option in CMake.
Not ready yet.
  • edit the dl_dxf.cpp file
  1. MPIR 2.6.0
Generate the project files
Compiling the project
Appendix
Common issues
        //#include <QElapsedTimer>
        #include <QTime>
        typedef QTime QElapsedTimer;
  2. to compile with Visual 2010 you must then apply the following patch: [3] (this solves a bug from the MSVC 2010 compiler that prevents Qt from running correctly in release mode)
    4. And follow this guide
