Rasterize
Revision as of 23:04, 3 December 2024 by Daniel (talk | contribs)
Input cloud
Generating a raster grid
'Rasterize' tool dialog
    • since version 2.13:
    • the minimum SF value
    • the average SF value
    • the maximum SF value
    • the median SF value
    • or the inverse variance
Empty cells
  • interpolate (see below)
Interpolating empty cells
Interpolate
Interpolation principle
Kriging
Kriging interpolation option
Grid position
Grid extents setup dialog
Raster grid
Interpolate scalar fields
    • median value
    • inverse variance
Resample input cloud
Export
Cloud
  • Since version 2.13:
    • 'median': median value
Raster
ASCII matrix
Contour plot generation
The user must specify:
Since version 2.6.2
Hillshade
  • click on generate
