Command line mode
-CROP2D {ortho_dim} {-GLOBAL_SHIFT + options} {n:number of vertices} X1 Y1 X2 Y2 ... Xn Yn Crops all loaded clouds inside or outisde a given 2D polyline. Cropping is done in a plane defined by its orthogonal dimension: X, Y or Z (i.e. coordinates along this dimension will be ignored).
  • Dim = X --> YZ
  • Dim = Y --> ZX
  • Dim = Z --> XY
  • COMPRESSED_BINARY
