Compass (plugin)
Revision as of 16:12, 24 July 2024 by Daniel (talk | contribs)
Map mode
Other tools
Add pinch node
Add note
Fit plane to GeoObject
Merge selected GeoObjects
Estimate structure normals
Export SVG
Further reading and citation
About the author
