Command line mode
Revision as of 11:28, 18 January 2024 by Daniel (talk | contribs)
    • INTERP = interpolate with Delaunay triangulation (inside the convex hull only)
  • -KRIGING_KNN {number of neighbors} to define the number of neighbors used for Kriging (if the '-EMPTY_FILL KRIGING' strategy is used - see above - default is 8)
