Command line mode
Revision as of 11:14, 22 December 2023 by Daniel (talk | contribs)
  • handle quoted arguments
-APPLY_TRANS {-INVERSE} {filename} applies a 4x4 transformation matrix to the loaded entities (clouds or meshes). The matrix is read from a simple text file with the matrix rows on each line (4 values per lines, 4 lines).
