Command line mode
-COMMAND_FILE{base name}
-ROUGH {kernel size}
-APPLY_TRANS {filename} {-INVERSE}
Use the sub-option -INVERSE to invert the transformation before applying it (since version 2.13). Notes:
-SET_GLOBAL_SHIFT {x} {y} {z} {-KEEP_ORIGIN}
Use the sub-option -KEEP_ORIGIN to maintain the global coordinates unchanged. This will in effect translate the points in the local coordinate system (a warning may be issued if the resulting coordinates are too big). Note: since version 2.13 |
