Command line mode
-COMMAND_FILE{base name} loads commands from a file.
  • handle quoted arguments
-SF_ARITHMETIC {SF index or name} {operation} {option} applies operations on a given scalar field of the loaded cloud/mesh.
-SF_OP {SF index or name} {operation} {value} applies an arithmetic operation on a given scalar field of the loaded cloud/mesh and with a given scalar value.
-SF_OP_SF {SF1 index or name} {operation} {SF2 index or name} applies an arithmetic operation on two scalar fields of the loaded cloud/mesh.
