Command line mode
| Command | Description | |||
Warning: must be first if required. | |||
Note: file type is automatically guessed from its extension. | |||
opens a LAS 1.3/1.4 file (waveform support) [Windows version only] | |||
saves all clouds in memory a LAS 1.3/1.4 files (waveform support) [Windows version only] | |||
Note: must be placed before the '-O' option. | |||
Removes all normals from the loaded entities. | |||
Note: Clouds without normals are simply ignored. | |||
Note: result is automatically saved by default (see the AUTO_SAVE command to change this). | |||
Note: result is automatically saved by default (see the AUTO_SAVE command to change this). This option is available since version 2.9. | |||
Note: creates a new scalar field (or overwrite any existing one with the same name) and sets it active. | |||
-ROUGH {kernel size}
-APPLY_TRANS {filename}
-RENAME_SF {SF index} {name}
Applies color levels to all loaded entities (clouds and meshes). The user must specify: | - the color bands (can be any mix of 'R', 'G' and 'B' - ex: 'G' or 'RB' or 'RGB') | - the input range (typically: 0 255) | - the output range
WARNING: the ADD_HEADER and ADD_PTS_COUNT options are broken in the 2.6.2 version. Use the latest 2.6.3 beta version instead. | |||
Note: default output format is binary (LE/BE depending on the current OS) | |||
to prevent CC from generating an automatic suffix (timestamp) for output file name (warning: this make the name of an output file predictable but if the file already exists it will be overwritten). | |||
Note: see below for more details. | |||
Removes the Global Shift information from all loaded entities. | |||
Enables (ON) or disables (OFF) automatic backup of clouds and meshes at each step (you'll have to manually call -SAVE_CLOUDS or -SAVE_MESHES at the right time/position in your command). | |||
closes all currently loaded entities. | |||
closes all currently loaded clouds. | |||
closes all currently loaded meshes. | |||
removes the last loaded cloud. | |||
removes the last loaded mesh. | |||
