Command line mode
-ROUGH {kernel size}
-APPLY_TRANS {filename}
-RENAME_SF {SF index} {name}
Applies color levels to all loaded entities (clouds and meshes). The user must specify:
- the color bands (can be any mix of 'R', 'G' and 'B' - ex: 'G' or 'RB' or 'RGB') - the input range (typically: 0 255) - the output range Note:
