Command line mode
Revision as of 11:44, 14 May 2021 by Daniel (talk | contribs)
-NOISE KNN/RADIUS {value 1} REL/ABS {value 2} -RIP applies the Noise filter on the loaded cloud(s).
Value 1: the caller has to choose between KNN (number of neighbors) or RADIUS (spherical neighborhood) Value 2: the caller has to choose between REL (multiplier of the local error standard deviation) or ABS (absolute error) -RIP: Remove Isolated Points (optional)
Example: '-CLEAN RADIUS 0.5 REL 1.0 -RIP'
