Command line mode
Revision as of 11:31, 5 October 2020 by Daniel (talk | contribs)
CloudCompare -M_EXPORT_FMT FBX -FBX -EXPORT_FMT FBX_Binary -O Foot.ply -NO_TIMESTAMP -SAVE_MESHES
