Command line mode
-ROUGH {kernel size}
-APPLY_TRANS {filename}
Specifies the default output format for groups (hierarchy objects). Mostly the BIN format, but other formats that support a collection of objects might be elligible. |
-FBX_EXPORT_FMT {format}
-SET_ACTIVE_SF {index}
