Compass (plugin)
Revision as of 12:01, 20 November 2018 by Sam (talk | contribs)
Map mode
Other tools
Add pinch node
Add note
Fit plane to GeoObject
Merge selected GeoObjects
Estimate structure normals
SNE estimation dialog explaining each of the available options.
Export SVG
Further reading and citation
