Compass (plugin)
Revision as of 07:37, 20 November 2018 by Sam (talk | contribs) (→Introduction)
Compass Mode: Extracting structural measurements
Map Mode
Other Tools
Add Pinch Node
Measure One-Point/Two-Point Thickness
Fit Plane to GeoObject
Merge selected GeoObjects
Export SVG
Saving and Exporting Measurements
Further Reading and Citation
