M3C2 (plugin)
Revision as of 10:50, 22 October 2017 by Daniel (talk | contribs) (→Introduction)
Precision Maps
Computing M3C2 distances
Main parameters
  • either the whole cloud
Precision maps
The Precision maps tab enables the calculation of detectable change to be carried out using measurement precision values stored in scalar fields of point clouds, rather than being estimated from roughness calculations. This ‘PM’ variant of M3C2 is described in James et al. (2017) and allows photogrammetric precision estimates to be used directly within the M3C2 workflow. If scalar fields are available, then the check box can be used to enable the ‘precision maps’ variant of M3C2. In this case, uncertainty estimates will no longer be made from roughness estimates at the projection scale in the Main Parameters tab, but will be based on 3-D point precision estimates stored in scalar fields. Ensure that the appropriate scalar fields are selected for both point clouds to describe measurement precision in X, Y and Z (sigmaX, sigmaY and sigmaZ). The scale can be changed if the precision values are in different units to the point coordinates. For example, if point coordinates and precision values are in metres, then the scale value is 1.000. However, if coordinates are in metres, but the scalar fields of precision are provided in millimetres, then the scale value should be set to 0.001.
Advanced
Output
Save/load parameters
Computing distance
