Command line mode
-MERGE_CLOUDS {filename}
-ROUGH {kernel size}
computes gradient of the active scalar field (or the first one if none is active) on the currently opened/generated cloud(s).
-APPLY_TRANS {filename}
-FBX_EXPORT_FMT {format}
-SET_ACTIVE_SF {index}
