Command line mode
-MERGE_CLOUDS {filename}
computes cloud-to-cloud distance on the two first loaded/generated clouds (1st = compared / 2nd = reference).
computes cloud-to-mesh distance between the first loaded/generated cloud (compared) and the first loaded mesh (reference).
computes density (inside a sphere around each point) on the currently opened/generated cloud(s).
-ROUGH {kernel size}
computes roughness with a given kernel size on the currently opened/generated cloud(s).
computes gradient of the active scalar field (or the first one if none is active) on the currently opened/generated cloud(s).
-APPLY_TRANS {filename}
-FBX_EXPORT_FMT {format}
-SET_ACTIVE_SF {index}
