Command line mode
  • -VERT_DIR {0=X/1=Y/2=Z} to specify the vertical direction (Z by default)
{type} can be MEAN or GAUSS.
  • -VERT_DIR {dim} to specify the projection dimension (0=X / 1=Y / 2=Z) - default is 2 (Z)
