CSF (plugin)
Revision as of 09:52, 1 July 2016 by Peng (talk | contribs)
P.S.
A mex version for programming in Matlab is at File Exchange of Mathworks website http://www.mathworks.com/matlabcentral/fileexchange/57918-csf--ground-filtering-of-point-cloud-based-on-cloth-simulation
Algorithm Details
Set up of parameters
General parameters
Scenes
Three options are under this parameter : Steep slope, Relief, and Flat. This parameter help users to set scenes type of the point clouds. When you set up this parameter, the rigidness will be determined actually.
Cloth resolution
Max iterations
Classification threshold
