CSF (plugin)
Revision as of 02:32, 22 June 2016 by Peng (talk | contribs)
P.S.
You can also visit the homepage : http://ramm.bnu.edu.cn/researchers/wumingzhang/english/default_contributions.htm
Algorithm Details
Set up of parameters
General parameters
Scenes
Cloth resolution
Max iterations
Classification threshold
