Display modes
Revision as of 11:17, 22 April 2016 by Daniel (talk | contribs)
Main display modes
Orthographic view
Perspective view
Object-centered
Viewer-based
Bubble-view (polar)
Note: the B shortcut can be used to enter this method.
Stereo mode
Anaglyph
Please note that:
NVidia 3D Vision
  • by pressing the F11 key
  • by clicking on the 'Leave fullscreen mode' icon that appears when the icon hovers the upper-left part of the screen
