Animation (plugin)
Revision as of 09:50, 8 October 2015 by Daniel (talk | contribs) (→Output video parameters)
Usage
Creating viewport objects
Animation parameters
In the upper part are listed all the animation 'steps' (i.e. the interpolated path between each viewport).
You can highlight a single step at once so as to setup its parameters (in the 'Current step' frame on the right). For now, only the step duration can be changed.
You'll also notice that when you highlight a step, the corresponding viewport is automatically applied.
  • and the output filename
Note that the video output format is automatically guessed from the extension (mpg, avi, etc.). The available output formats depend on the codecs installed on your machine.
To setup the bitrate, you can follow
Rendering
Saving the parameters
Tutorial
