RANSAC Shape Detection (plugin)
Revision as of 16:30, 20 February 2015 by Daniel (talk | contribs) (Daniel moved page PluginRansacSD to RANSAC Shape Detection (plugin))
qRansacSD stands for "RANSAC Shape Detection" and is a simple interface to the automatic shape detection algorithm proposed by Ruwen Schnabel et al. of Bonn university.
This is exactly the same implementation as the library shared by the authors on their website (version 1.1).
Usage
  • to use this plugin, the user must select a point cloud
  • to obtain better results, you can provide a point cloud with clean normals (otherwise the plugin will compute them itself)
  • a point cloud corresponding to the subset of points that supports the detected primitive. The name of the cloud incorporates the estimated primitives parameters
  • the corresponding entity as child of this cloud. Warning: apart for planes, the other primitives are not displayed by default (as they can be much bigger than the actual cloud, especially for spherical or cylindrical portions that may only fit on a very small portion of the complete primitive).
  • each couple (cloud/primitive) is randomly colored
