Interactive Segmentation Tool
Revision as of 22:36, 17 February 2015 by Daniel (talk | contribs) (→About mesh segmentation)
This tool is accessible via the icon in the main upper toolbar or the 'Edit > Segment' menu.
"Interactive Segmentation" tool in action
Polygon edition mode
  • left click: create a new polygon vertex
  • right after the first vertex is created, you'll see that the first polygon edge will start to "follow" the mouse cursor. You have to define the position of the second vertex (left click) in order to 'fix' it. This process will start over with the next edge and so on.
  • right click: stop the polygon edition (warning: the currently 'floating' vertex won't be added to the polygon)
Rectangle edition mode
In 'Rectangle edition' mode you have to left click a first time to define the first corner of the rectangle then click a second time to define the opposite corner (alternatively you can keep the left mouse button pressed and the opposite corner will be created once you release the button).
Segmentation
Otherwise the user has to choose whether to keep points inside () or outside () the polygon. Once done the other points will disappear (as well as the polygon).
Paused mode
  • modify the current entities orientation and segment more points (click on the button to leave the 'paused' mode and define a new polygon/rectangle)
  • reset the current selection ()
  • validate the current segmentation and create two clouds: one with the selected points and one with the others ()
  • validate the current segmentation and create only one cloud with the visible points () - the other points will be deleted
  • cancel the segmentation process () (no modification will occur)
Polygon Import / Export
Import
CC will display a simple list of all polylines it founds in the DB tree so that the user can select the one he wants to use.
Warning: any previously defined polygon/rectangle will be discarded.
Export
Close-up of mesh segmentation near the polygon edges (original mesh is shown as wireframe and the segmented mesh is in plain colors - the polygon edge is in green
Shortcuts
Shortcut Description
Space bar Toggle 'pause' mode
Escape key Cancel
Return key Apply
Delete key Apply + delete hidden points
Tab Switch between polygon and rectangle edition mode
CTRL key (pressed) Use a rectangular selection area (whatever the edition mode)
I Select points inside
O Select points outside
