Scalar fields\Export coordinate(s) to SF(s)
Revision as of 13:22, 9 February 2015 by Daniel (talk | contribs)
This tool is accessible via the 'Edit > Scalar fields > Export coordinate(s) to SF(s)' menu or the 'Tools > Projection > Export coordinate(s) to SF(s)' menu.
This tool lets the user export the points coordinates to one or several scalar fields.
CloudCompare will ask the user to select the source dimension(s):
Edit > Scalar Fields > Export coordinate(s) as SF(s) dialog
Each dimension will be exported to a scalar field with a predefined name ('Coord. X', 'Coord. Y' and 'Coord. Z').
Z coordinates exported to a new scalar field
Warning: if a scalar field with the same name exists, it will be overwritten.
